Can a charge cooler leak cause hydrolock and engine destruction?
c_paul
My t6 204 is slowly losing coolant (separate thread).
One of the symptoms is that about half a dozen times the starter motor has struggled to turn the engine over.
It turns over for a bit then freezes as if there isn’t enough power to turn the engine over.
But battery and starter are strong.
Given the coolant loss issue, could it be coolant lost in the charge cooler going into a cylinder causing a slight hydrolock?
My concern is that it causes major engine damage.
The current advice from vw specialist is watchful waiting.
Pressure test all came back normal.
Coolant loss is sporadic. Wont lose any for a while then loses 200ml.
Total loss has been about 1.5l in 6 months so not very much.
No oil contamination, water contamination or mayo.
No visible leaks.
No steam in the exhaust.
I am worried that waiting could cause catastrophic engine damage.
What does everyone think?
Egr valve coolant leak can cause loss without any signs.
If it's hard turning, it may be head issues but that's really going down the omg I'm going to lose my marbles route and is unlikely before other omg it's dead now things happen...
Yes, water in the engine can damage it.
If your that concerned, the only way to test if your getting water into the cylinder is by removing an injector/glow plug and seeing if the bore is wet with water/coolant after re creating the scenario in which you then suffer a hard start.
There's four common coolant loss failure points.
I reckon identify which of those four it is (I can't remember but there is somewhere on here that mentions it, one of them is the egr valve, or some part there of... Ask me how I know...) And you are probably going to be ok.
In my case I was loosing a litre every 250 miles! Pretty ruddy bad! Only used two litres of diluted and it sat the dealers from this point for two months as I was where you were... Rather not risk it.
To be fair though, the two issues may not be related and a hard start can be caused by a plethora of issues, so much so, that if you have a porblem that you think may cause the said problem, use a method to find this out (hence one of the above paragraphs)
No visible leaks.
Where you able to resolve this?
Sadly not. Yet.
Am currently looking for a specialist.
I have work out:
After a reasonable journey the coolant system is under excess pressure that remains after the system has cooled.
If I don’t release this pressure it will cause a hard start / hydrolock situation.
Oil is clean. Economy has fallen through the floor. Engine running okay ish. Bit rough. Regen every 150 miles ish.
My current hypothesis is cracked head which has caused bent conrod.
I vw specialist wants £1600 to change egr as first port of call. I think i want to take it to an engine specialist to check internal condition first.
