On an original California 3 rails installation, I believe the middle rail is shorter than the 2 outers. Is this correct? Could an owner provide the length measurements of the rail ali caps please?
ill be able to look on Thursday for you if thats any good, unless somebody gets back to you beforehand that is
The middle rail is just for a seat addition if i remember
Not that I can remember. I think it’s similar to the caravelle set up.
It disappears under the seat/bed so I can’t say I’ve ever seen the other end of it
I’ll have a gander and revert
Thanks @Deaky & @paulscryer . Interestingly, VW have the centre rail under a different part number while the 2 outers are the same. I'll probably prise one off as the part number is stamped underside.
