Yep they've had both since 2006 AFAIK. Our last Cali was the same.Open the drivers door and look at the labels on the edge.
Mine has 2 an Eberspacher and a webasto.
Spot on but why are there twoOpen the drivers door and look at the labels on the edge.
One is a diesel heater the other is an engine pre heater; or something like that.Spot on but why are there two
Thanks for that do you know which is whichOne is a diesel heater the other is an engine pre heater; or something like that.
I just switch it on, the van warms up.
Thanks for that I have been looking at the ebersacher D2 with the 702 programmer and also the phone app kit .Webasto is the engine preheater and the eberspacher is the air space heater
Someone else will correct / confirm, I’m sure,With the heaters is there any problem if you go for the petrol van?
Webasto do petrol heaters 2Kw, 3.5Kw, 3.9Kw, 4Kw, 5Kw and 5.5Kw. I think that I am correct in saying that Eberspächer only do a 4Kw one now.
Who couldn't give you an answer? What parts were unavailable? It is only the burner and ecu that are different on a petrol Webasto. Which model were you looking at? Are you you sure that you were not just being fobbed off by someone that didn't want the business?
A lot of questions there but it does appear to be odd to be given that information.
Which model was that, as I bought 2 new Air Top 2000STC petrol ecus in the summer no problem. That only leaves the burner which is the same as the 2000S and ST and they were certainly available also!
I did notice that the STC petrol wasn't on one main dealer's website for a month or so in the summer though.
