I've gone a few k miles after the first warning from the sensor ... depends how heavy you are and how you drive, as to much run time you have left on a pad set.
Also depends how lipped your disc is. (If it's lipped bad you will get grinding before the friction material is fully done)
But as soon as you start to get a grinding noise under breaking....... then it's time stop and get them done immediately.
