Bmw 5 series wheels on t6
Cjscos
hi all
Will bmw 5 series wheels with a 8.5j x20 and 10jx20 wider rear with a load rating of 825kg per wheel fit on a t6 t32?
The load rating is fine ( or so i think!) as this adds up to 3300kg but I am not sure what offset they are?
The loading on axles is not equal - more on one than the other. It will depend on the specific T32. There is a metal plate on the vehicle which tells you the split front to back. A quick search should help as I can’t recall the thread it was on.
Pete
10jx20 ET40
8.5j x 20 ET 20
Would these fit?
That rear offset is fine, but the front offset might give you some trouble on the outside edge, especially if you're lowered. I wouldn't recommend anything lower than a 35mm offset on 8.5" wide fronts.
On the subject of load ratings, if you want to be fully legal on T32 you need a minimum load rating of 860kg per wheel. Axle weights on T32 are 1720 rear and 1710 front.
Message @BognorMotors and see what OZ wheels he can get for your van that are fully compliant.
I love OZ’s, I had a set on my Impreza many many years ago, I’d love a set of 21’s on my bus if possible.
Yes we are an Oz dealer, sent your request through on our website contact form and we can price them for you
