Bluetooth energy monitor 240v
Cnud
Anyone recommend a Bluetooth energy monitor I can use for my 240v hook up? Just want to check usage and make sure I’m not pulling 16 amps! Thanks!
You`d be pulling a seriously large amount of current to trip the 16Amp breaker on 230V (3680 Watts). We have usual T6 conversion with a microwave and no worries.
Heres one option.
due to the high power level (16A @ 240vac / 3840watts max)(as mentioned above) you will need either a clamp meter style or an inline hardwire version.
clamp meter style can be fitted in the bus at the Dis-board - or hardwire in a separate box.
what about a Bluetooth clamp style meter . . . . for spot testing?
Whoa, more than helpful thanks. We have been known to trip the old hook up breaker, normally when the mrs is making a cuppa, whilst hair drying with the fan heater on in the awning full blast. There’s only so many times you can explain things!
