We’ve run loads of 275/35/20 on 8.5 - You will have no issues. Even though the recommended is narrower.
You can run the 265/40/20 as an option, if you want to run a narrower tyre - If you are T32, then this is the one to go for, for the 104 load rating.
@Shredder, the difference between a 38 and a 45 offset is 7mm.
You haven't said how wide your wheels are, but by way of comparison, the difference between an 8.5" wide rim and a 9" wide rim is 12.7mm.
If you want to learn about tyre sizes, the best place to look is with a tool like this: Will They Fit - Online Wheel and Tyre Fitment Calculator
Enter the size of the standard wheels and tyres and then find one that matches the overall size on the new wheels.
The problems start to appear with available sizes, load ratings etc etc.
Also remember that the profile figure (e.g. 40, 45) is a percentage not an actual measurement. So a 245/45 r19 has the same sidewall height as a 275/40 r19 - both are 110mm.
Thanks I’m just having a bit of a flap about tyres. I think they’re the ones I need anyway
It’s on air.
The real ET would actually be 35 ... years old
Thanks for reminding me i'm not 18 anymore.
And who on earth phones home anymore!
Think we've digressed again @Tourershine![]()
