Hi all,
I have recently joined this forum as a first time T6 owner, only had the van a couple of weeks but already upgrading!
I just installed some new sequential side indicators and rear barn door brake lights from Thq along with swapping out the interior cab lights with leds. After going away for the weekend I have found the battery nearly flat and only able to start after charging it for a few hours.
After checking with a multimeter the pull is around 1.6A, is it likely the new lights are the issue? They all work exactly as they should and I have checked the internal lights to make sure they are turned off.
Is there a way to check what is causing this as I don’t want to remove the new lights without knowing for sure, the adhesive seals they come with would be ruined.
Any help would be much appreciated!
