Battery control panel 0%
Emmala93
Our control panel is saying that the battery percentage is 0 and the voltage is 0 however the fridge, lights and usb ports are still working?? Really confused. We have hooked the van up to EHU but it’s not changing anything on the control panel??
It’s really difficult to suggest anything as we don’t know how your van electrics are configured.
Do you have any sort of manual or written description of what you have ?
Pete
Post some pics of the leisure battery and shunt.
This is normally caused by the shunt being wired incorrectly, which will cause a iffy reading.
Would also be useful to know what all those switches do too.
Pete
The switches…
Top left - electric hook up battery charge.
Top right - water pump
Bottom left - lights
Bottom right - fridge
It could be the meter which has become open circuit from the battery. Check the meter's connections.
this meter . . .
Ampnogy AiLi Battery Monitor​
whats the settings for the battery set to?
ill attach the pdf for it here . .
  • Low Price Ali battery Monitor.pdf
get a better pic of this sticker for the battery spec. . .
assuming its a standard 100ah lead acid. . .
you would need to set the meter battery rated capacity as a 50ah battery (due to SLA 50% DoD)
then fully charge the battery with a smart mains charger to sync the 100% SOC.
then see how you get on.
do you have a voltmeter on the van?
more info:
So as we thought.
Standard wet flooded SLI battery.
Not AGM or other.
So the 50% dod applies.
Set the battery capacity to 50ah...
Does the fridge etc work when not connected to ehu. Are all of those switches turned off, don't they allow the 12v circuits to operate.
So it charged overnight and was on 100% this morning but then when my dad went in the van it went down to 0% in about 15 minutes! So strange
