C Cahn New Member 30 Mar 2026 #1 Hi I am very new here - as you can tell from this question "how can I open this, I think it is the electric hook up flap?" Thank you CAHN
M Macp Senior Member VIP Member T6 Guru 30 Mar 2026 #2 Dont you just pull it, and its on a spring so flicks shut.
L Lubrown Senior Member T6 Legend 30 Mar 2026 #3 Mine just pulls up from the bottom edge. It clicks shut (not the strongest click ever) to stop it flapping in the wind.
C Cahn New Member 30 Mar 2026 #4 Thank you both - I did try that but it didn't seem to move so wondered if there was some kind of release... maybe I will try a bit harder ...
Salty Spuds Senior Member VCDS User VIP Member T6 Legend 30 Mar 2026 #5 Cahn said: Thank you both - I did try that but it didn't seem to move so wondered if there was some kind of release... maybe I will try a bit harder ... Click to expand... They need a good tug…
L Lubrown Senior Member T6 Legend 30 Mar 2026 #6 Cahn said: Thank you both - I did try that but it didn't seem to move so wondered if there was some kind of release... maybe I will try a bit harder ... Click to expand... Could always try sliding an old credit card around the gap - sides and bottom edge, just to release it a little without too much pressure
C Cahn New Member 30 Mar 2026 #7 Great thanks both will try these out.. was afraid of pulling too hard and the whole thing coming off!
Sackmycook Leisuredrive Vivante VIP Member T6 Legend 30 Mar 2026 #8 As above, lift up from bottom. They are designed to be stiff
S SlightlyDisturbed Senior Member VIP Member T6 Guru 30 Mar 2026 #9 Salty Spuds said: They need a good tug… Click to expand... The perfect response for your username
