www.dorsetleisurecentre.co.uk
Does anyone know if you can buy a long length of anything to replace the short lengths figure of 8 for an awning fixing kit.
@Camper essentialCamper essentials I got Mine from
If you could.The issue I have is that the figure of 8 plastic rods tend to part from each other allowing water to drip through. The only solution so far is to join them with blue tac. Two small rubber tubes glued together with a split along the length of each one is what I am looking at to design. The problem is finding the right diameter tubing strong enough hold.im currently designing just the thing but will be a few weeks before I have it ready. Would you like me to message you then?
I've had the same issue with those figure of 8 pieces, they leak and in a strong wind have fallen out at times. I'm looking at manufacturing one piece rubber extrusion. I'm just designing the die tool but will get back to you.If you could.The issue I have is that the figure of 8 plastic rods tend to part from each other allowing water to drip through. The only solution so far is to join them with blue tac. Two small rubber tubes glued together with a split along the length of each one is what I am looking at to design. The problem is finding the right diameter tubing strong enough hold.
Hi @Mattmoo. Did you make any progress on this?I've had the same issue with those figure of 8 pieces, they leak and in a strong wind have fallen out at times. I'm looking at manufacturing one piece rubber extrusion. I'm just designing the die tool but will get back to you.
Thanks for the update. I look forward to hearing from you.Hi, I'm getting there. I've had some prototypes manufactured and tested. I just need to tie up some details with the manufacturer when I'm back from my holiday.
It's taken longer than planned to get all the testing done but it's looking promising but I want to get it right before it hits the market.
You will be one of the first people I contact when it's ready though.
Regards
Matt
