So i have been working on a 2021 kombi the last few days installing cabling for some retrofits, i have run some cabling in but nothing is connected yet
I had to fire the van up and move it with some stuff disconnected and since then the van is showing an error, the display says Tyre Pressure Loss Indicator currently not available
Ignored it and carried on thinking it will go when everything is back together etc so now i have everything back together and taken it for a drive everything has cleared except this
Did a scan with VCDS and module 3 ABS is showing an EEPROM Malfunction, i can clear it then it returns as soon as i look at tyre settings or cycle the ignition, tyre indicator is present on dash and flashing away so i know that is working
Open to ideas and suggestions of things to try
Ignore the 09 error, headlights are unplugged
Tuesday,14,June,2022,14:10:16:19930
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220530 DS337.1
www.Ross-Tech.com
VIN: WV1ZZZ7HZMH115295 License Plate:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 18 19 44 5F 75
VIN: WV1ZZZ7HZMH115295 Mileage: 14729km-9152miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: OK 0000
Address 01: Engine (J623-DNAA) Labels: None
Part No SW: 05L 906 023 B HW: 05L 907 309 F
Component: R4 2.0l TDI H80 1162
Revision: N1H80--- CVN: 0D2AE0A4F3218A0EA3C795CF64CF85E9A3C795CF43FB2DAA
Coding: 0019003C0344050800000000000000000000000000000000
Shop #: WSC 00012 790 00041
ASAM Dataset: EV_ECM20TDI01105L906023B 006006
ROD: EV_ECM20TDI01105L906023B.rod
VCID: 270BF1765F69C993AE5-8072
VINID: 9E606AAAA1D8A9D601045089149E2FC577
No fault code found.
Readiness: 0 0 0 1 1
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 7LB 614 517 B HW: 7LB 614 517
Component: ESC_base H01 0800
Serial number: 08514181210423
Coding: 10552752C848E68A0856E4AD136B6726393324B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3FDB4916A7F96153F65-806A
1 Fault Found:
1262 - TPMS Display
C1146 F2 [137] - EEPROM Malfunction
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Mileage: 14729 km
Date: 2022.06.14
Time: 02:06:56
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 7LA 907 426 D HW: 7LA 907 426 D
Component: AC Manuell H01 0602
Coding: B03110000810230001000800504001050000000000010000A00000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA.rod
VCID: 44D146FACE1F028BAB7-8010
Rear A/C control head:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 2Q0 937 090 C HW: 2Q0 937 090 C
Component: BCM A0 Std+ H11 0943
Serial number: 00102112400442
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BCMA0 206001
ROD: EV_BCMA0_206_VW26.rod
VCID: 323D102264ABBC3B09B-8066
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S5Y21M04D21H02M09S10
Coding: 0018EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000049767060
Coding: 1F0007
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000049799353
Coding: 050007
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY210852ECN
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000049427612
1 Fault Found:
8202 - Bulb for Left DRL
B121D 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 35
Mileage: 14729 km
Date: 2022.06.14
Time: 02:06:29
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.0 V
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058321113
Coding: 8451051801
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000.rod
VCID: 53F375A63B71953322D-8006
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A00600201FF8748949C815560508700000000000000000004
Shop #: WSC 00012 790 00155
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D345E6CB1105B392D-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 016 0506
Revision: --------
Coding: 8800C00000000000400000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 7F5B0916E779A153B65-802A
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI3
Part No SW: 7LA 920 941 A HW: 7LA 920 941 A
Component: KOMBI 202 8500
Coding: 27A512022580260001882A010401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 3E253412A0F3685BFD3-806A
Address 18: Aux. Heat (J364) Labels:* Redir Fail!
Part No SW: 5WA 963 271 C HW: 5WA 963 271 C
Component: STH-VW37x 006 0012
Serial number: 000000000000113
Coding: 3143221854121512DCE519
ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
ROD: EV_AuxilHeateWOSVW38X_002.rod
VCID: 4CC16EDAE64FCACB637-8018
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 25042111604243
Coding: 030100044F05730000000058000F00010001070000000000000000000000
GVL: 01443C0000000000400080008004480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 74B1D63ADE3FF20BDB7-8020
Generator:
Component: 5-00-11-00-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440036089214096
Coding: 2C0D00
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 77343301002104200385
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 G HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7160
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002015
ROD: EV_SteerAssisMNB.rod
VCID: 46D55CF2F823309BB53-8012
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 3CN 035 869 A HW: 3CN 035 869 A
Component: MU-E-D-ER 720 0890
Serial number: 17022100021231
Coding: 066401003C00000041110101008000001F0000D60000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0092
Serial number: 0000000104NVYK1
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW27.rod
VCID: 015F8FEE918DD7A3C01-8054
End----(Elapsed Time: 01:18, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
