If the wall plate unbolts, give some consideration to dropping it off again. (I know that's a ball-ache and I'm guessing you're doing the job on your own which makes it more challenging.)
By dropping it off the wall, you can "dry build" the roof on the ground doing the angles and notches you need. Then, when you get the wall plate back up, it will go together like Lego for you. You'll get to space your centres as you want them and deal with the soil/waste stack on the ground rather than working at a height. If you screw each joist from the top and the bottom along with a screw at an angle into each joist through the top of the wall plate, there's no need for ugly hangers.
Don't forget to run a silicone bead to seal where the wall plate meets the house (and a good dab on top of each screw you put in from above) as it is a moisture trap and could rot out the wall-plate more quickly.
