2250lbs = 1020kg = 109 load rating roughly @ 70psi
So on the face of it, you could increase your pressures if you feel the need to upto 70psi, and still be in the safety limits of the tyre.
The down side can be lower grip levels; more bounce; less precise straight line stability; uneven tyre wear etc etc.
It might be worth a trip to a weigh bridge to get your front and rear axel loads in running order, with your normal passengers/water/fuel/gas/items etc etc in your T6. I guess your maximum axel loads would be around 1610kg(ish), your VW handbook should confirm this.
There is a method with a tray of wet sand looking for even imprints in the sand to show how even your tread wear will be.
Some tyre manufactures will you advise on tyre pressures for certain loadings.
Roughly speaking if your tyre at 30psi would support 500kg (car loading), and at 70psi support 1020kg;
Your loads are 1620kg/2=810kg per wheel roughly:
Then each psi above 30psi supports an extra 13kg.
So to support 81okg that would be 30psi + (310kg/13kg/psi)=
54psi
I don't feel qualified to advise you any further, email Nokian Technical and see what they say
But on the face of it you may be right, but please don't take my word for it.
