Alignment Q - thoughts on rear toe
kombisnaps
T6.1 Kombi
Just had the van aligned after dropping about 40mm - all good and in the green.
My only quick Q for people would be do they think the toe is okay on the rear as it's close to limits?
Front is bob on and the tech at the alignment said they tend to leave them a bit toe'd on lowered vans - but am just wondering why / if it'll make much difference being within parameters.
Nice to have a full house of green though!
Edit - would be good to hear from people with similar rea toe about miles from tyres and all that. Had my original alignment at standard height done by @BognorMotors and toe was only .01 off on the rear and tyre wear has been perfect over the last 8000 miles
Hi, if you are in the green that’s about as good as it gets. I have mine checked every 12 months as the geometry does get deranged with the awful UK roads. I’m Running 20” and I get approximately 15 -18k with no uneven wear which for a heavy vehicle and lots of towing is not bad.
Sounds good
I’m going to see if my local shop can nip the toe in at the back a little more and get thrust to 0 then I’ll probably be happy.
