Airbag module and other codes
Stevefrs
Fuel Process Engineer
VCDS User
I recently went to clear another members airbag light that had come on after a seat removal and when scanned I found the below faults. I tried to access the airbag module directly but it was coming up that it and the 5F information Electr cannot be reached.
My thoughts are a blown fuse or 2 but wondered if others had seen similar. I didnt have time to dig any further but hoping somebody might have seen something similar.
I have attached the scan as well.
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Cannot be reached 1100
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
Certainly looks like some controllers are offline - either no power and/or data buses down.
I'd start by clearing faults (in each module individually) and then redo the scan to see which faults remain.
Getting 15-Airbags back online will solve majority of the faults.
Thanks, I will get back to the member and see if he can confirm whether he found power feed problems.
Missing 5F is normally when the headunit has been swapped for aftermarket
Hi stevefrs
I've been through both fuse box,s and cant find anything blown
Does anyone know where the airbag module is incase I've dislodged something
Fairly certain it is between the seats near to the dash.
I can come and give it another scan and see what else we can clear if you want.
That would be great , im busy tonight and tommorow day but anytime after that to obviously suit yourself as your so kind to put yourself out
