I removed this from our van a week or so ago, and replaced it with a Victron device, just because I wanted Bluetooth monitoring/management, and I have other Victron devices in the van.
I installed it from new about 4-5 years ago, and it's been perfect - a fit and forget 30 Amp proper leisure battery charger, set for an AGM battery.
As you can see from the image, I cut the wiring to it to suit my new Victron installation, so the ground and output wires are a little short, but I can solder and heat shrink more wire on if you want.
The Red Input cable has a spade connector on, as does the Yellow Sense wire.
This is an older model, so is not immediately compatible with the Bluetooth module sold by Ablemail, but they have confirmed it can be returned to them and re-programmed to work with that module. It can also be re-programmed for Lithium etc.
As it comes, the device switches on/off automatically by battery voltage sensing, but again Ablemail can re-programme it to work with an ignition feed.
These are £225 new, so £60 + postage seems fair.
Thanks for looking,
Pete
Thanks for looking,
Pete
