2nd battery cable sizing?
Paynewright
T6 Legend
I want to run a fused cable from the ebox to under the drivers seat to install a fuse box and potentially at some point fit a leisure battery.
What is the recommended size cable to future proof the install so I only run it once?
Ian
Currently it will power 1x 12v socket, two ign switched USB outlets, the extra fuse box under the passenger seat (needed for tow bar install and rated at 60A) and aux power to the towbar socket (15A)
Can anyone advise on the cable route from the ebox to the cab. Fuse #3 is empty.
Researched and found the route from the battery through the grommet behind the battery and a second grommet over the strut top into the cabin.
Just wondered what the route is from the ebox?
Ian
some more info here:
