Just when I thought I had all my 20" T32 tyre wrangling clear in my head and I'm thinking about new tyres, another issue crops up. To recap, my van has 20" Zito 935 wheels and tyres are 275/40/20 106 front and back as the van was supplied to me, so all good there (I know many prefer 265/40/20 but the 275s are working perfectly well for me with no rubbing or issues on a 40mm drop).
I've only ever taken a front wheel off to check the load rating and it was clearly stamped on the back 900kg so all good there too. However, I'd never really taken much notice of it before but the front wheel I've had off is stamped 8.5JJ. Now (after some research) I understand the difference between a J wheel and a JJ wheel and I'm not particularly bothered by that. But a 275mm wide tyre on a 8.5" wheel? Everything I've read suggests that isn't recommended or even possible with some tyres.
I've never really noticed it before but the front tyre sidewalls do seem to 'bulge' very slightly more than the rears, although it is hardly noticable. I have a feeling (that will only be confirmed when I whip a rear wheel off over the weekend) that I'm going to find my van has staggered wheels (8.5 at the front and 9 or 9.5 at the rear) and I didn't know but the same tyres on both. It is a 4Motion so I understand why you would want to keep the tyres the same front and back but surely because of that you would have kept the wheels the same too? I suppose that then begs the question can you put a 9 or 9.5 20" wheel on the front with a 275/40 tyre without issue? Or do I look to get narrower fronts that match the rear's circumference as best I can and hope that doesn't cause a 4Motion issue?
Just when I thought I had it all clear in my mind I'm stuck again......
