We have a T32 TDi 204 DSG......
and while we don't pull a caravan or trailer we are fully loaded at about 3.2ton total weight and have no problems with power.
Gear ratios are spot on for a 7 speed box and the engine power has more than enough tourqe.
heres some official bumf . . . . .
VW Transporter T6 towing capacity
Unbraked towing capacity on all T6 Transporters is 750kg.
Braked towing capacity ranges from 1,800kg to 2,500kg on SWB panel van models, and from 2,200kg to 2,500kg on LWB panel van models.
Kombi models range from 2,200kg to 2,500kg braked, regardless of bodylength.
VW Transporter T6 SWB panel van payload ratings
GVW model Official VW payload Payload + 75kg
T26 715kg 790kg
T27 836kg 911kg
T28 768-917kg 843-992kg
T30 968-1,117kg 1,043-1,192kg
T32 1,043-1,271kg 1,118-1,346kg
VW Transporter T6 LWB panel van payload ratings
T28 745-860kg 820-935kg
T30 912-1.060kg 987-1,135kg
T32 987-1,244kg 1,062-1,319kg
As with all vans, exact payload amounts will vary with trim level, engine type and fitted equipment.
Kombi models - which are available in T30 and T32 variants only - have approximately 100kg less payload capacity than the equivalent panel van.
source :
Volkswagen Transporter van dimensions (2015-on), capacity, payload, volume, towing | Parkers
Dellmassive`s -- "how I Done It" -- Thread
