Hi all,
I’m trying to figure out a weird issue with my 2024 California Ocean 6.1 and I’m hoping someone here has seen something similar.
When I slow the car down, the front assist / parking sensor system behaves strangely:
When the car is fully stopped, everything seems normal:
So the system itself clearly works — just not during low-speed movement / braking.
I’m wondering if this could be:
The issue
- The front middle-left sensor always goes red
- It starts beeping loudly every time I decelerate or creep forward
- This happens even when:
- The bumper/sensor area is clean
- There is nothing in front of the car
- No visible obstruction at all
What’s confusing
- If I manually enable the parking sensors while stationary:
- All sensors work correctly
- No constant red warning
- Distance detection is accurate
- Pedestrians walking in front are detected properly
What I’ve checked so far
- Sensor is clean (no dirt, ice, water, etc.)
- Nothing physically blocking the bumper
- Issue is always the same sensor (front middle-left)
- Works fine in stationary mode
- Problem only appears when the car is rolling slowly / slowing down
My questions
Has anyone seen this behavior before?I’m wondering if this could be:
- A faulty ultrasonic sensor that only fails under vibration/motion
- A loose connector or wiring issue behind the bumper
- Calibration issue between parking sensors and front assist system
- Software glitch during deceleration (sensor fusion issue?)
Any advice appreciated
Before I book a service visit, I’d like to narrow down whether this is:- A known software bug / reset fix
- Or something physical with the sensor or wiring
