2016 T6 102, Stolen / Recovered. Charging Fault [Resolved]
notchback
Hi.
I'm new to the forum and just purchased my first T6 (Had a T5 for years) Hope someone might be able to help to resolve a problem?
I've just purchased a Stolen / Recovered 2016 Kombi from an insurance company. It's only done 20,000 miles, in reasonably good condition too.
Basically, the van had been parked up for several months and the battery was completely dead. I replaced the battery and it started first turn of the key and drives perfectly, however, when I put a multi-meter on the battery I discovered the alternator is not charging.
As far as I can see, all the cables look to be connected correctly, and there is no visible damage. I have also noticed that the instrument cluster has previously been removed and refitted quite badly (the rev counter is slightly twisted anti clockwise?) I'm guessing there must be something in the cluster or behind it the thieves needed access to? Is there anything in this area that could potentially affect the charging circuit?
I do have Ross-Tech VCDS, and after running a scan it comes up with 2 faults, Codes posted below:
Any suggestions would be much appreciated! Thank you!
Code:
Wednesday,19,August,2020,20:25:05:41168
VCDS Version: Release 20.4.1 (x64) Running on Windows 8.1 x64
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
                Address 01: Engine       Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 KA    HW: 04L 907 445
  Component and/or Version: R4 2.0l TDI   H02 4047
           Software Coding: 00114014430401090000
            Work Shop Code: WSC 00000 790 50316
              ASAM Dataset: EV_ECM20TDI03004L906056KA 004003 (VN75)
                       ROD: EV_ECM20TDI03004L906056JS_004.rod
                      VCID: 76B5E5B0084D30BB797-8022
1 Fault Found:
25796 - Body Control Module (Central Electric)
          U0140 00 [039] - No Communications
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 35051 km
                    Date: 2031.01.22
                    Time: 02:14:10
                    Engine speed: 827.00 /min
                    Normed load value: 22.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 75 °C
                    Intake air temperature: 40 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 11.382 V
                    Accelerator pedal travel: raw value: 0.00 %
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: main switch off
                    selected gear: Shifting process active
Readiness: N/A
[U]SECOND FAULT: [/U]______________________________
BATTERY REGULATOR – Status malfunction
Wednesday,19,August,2020,20:19:11:41168
                Address 61: Battery Regul.       Labels: 1K0-907-534.clb
Control Module Part Number: 7E0 907 534     HW: 7E0 937 090
  Component and/or Version: Batt.regelung H81 0744
           Software Coding: 030B1A73
            Work Shop Code: WSC 02739 790 00000
                      VCID: 6889BBC85279D64BFBB-803C
1 Fault Found:
02252 - Generator
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 34913 km
                    Time Indication: 0
                    Date: 2020.08.19
                    Time: 00:01:00
This might sound daft, but have you checked it’s putting a charge in when it’s driven?
They may have been looking for a tracking device.
Batt reg fault.
Look at battery neg post and make sure the power sensor is connected.
The alternator won’t charge if the battery is over 80%. Turn on the lights heater, heated sets if you have and test again.
might need to replace the module on the battery negative terminal.
Hi, yes I collected the van from Kent and had to drive it back to Cardiff. It flattened the battery twice (we had to stop and swap the battery from my T5 so we could continue driving it)
Batt reg fault.
Hi, Yes the small connector is on the negative terminal, and I have traced that cable back as far as I could and I could find no damage. I could do a continuity test if I knew where the other end of those wires were though?
That could make sense, the main computer brain isn't back there is it? I wondered if they might have been trying to replace it to disguise the identity of the van perhaps?
I've no idea, I do know that thieves will often strip a vehicle looking for a tracker, but it's anybody's guess what they were up to! (Sadly they didn't think about doing an honest days work instead.)
Useful information you didn’t mention :rolleyes:
sounds like a can bus fault in that there is no communication between engine module and BCU and battery module. Are all the fuses present and good? (look for fuse slots with both metal inserts but no fuse)
The OP mentions.
BCU,
Battery regulator,
Generator,(alternator)
And no comms.
So you need to start with the basics and see what the no com is.
Like @Loz said check all the fuses are present and in the correct slot. Including the ones under the battry.
The BCM is above the peddles...above behind the clocks.
BCM and ECM must have comms for it to start....
So look over the alternator connections also.... its LIN bus back to ECM.
Post another scan after clearing all faults.
Also post a full scan of all the present modules, or the list of present modules.
Looking like the main issue is a no com with alternator.
The OP mentions.
BCU,
Battery regulator,
And no comms.
Thanks for your suggestions, I'm going to pull the battery tray out in the morning and confirm all the fuses are ok. The clocks had previously been removed, so you think it is possible they have disturbed something back there? Although the van starts and drives fine.
I'm fairly new to modern vehicles so still learning a lot about the Ross-Tech software and terminology. What is meant by LIN bus back to ECM?
Thanks.
The OP mentions.
BCU,
Battery regulator,
And no comms.
Here is the latest full scan, and I have expanded the Engine fault at the bottom:
Code:
Sunday,23,August,2020,21:18:40:41168
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZHH029878 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZHH029878 Mileage: 35310km-21940miles
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (2D2D2-CXGB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KA HW: 04L 907 445
Component: R4 2.0l TDI H02 4047
Revision: 23002001
Shop #: WSC 00000 790 50316
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35311 km
Date: 2031.01.25
Time: 06:46:37
Engine speed: 855.00 /min
Normed load value: 26.3 %
Coolant temperature: 22 °C
Intake air temperature: 15 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.359 V
15916 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 00 [039] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35311 km
Date: 2031.01.25
Time: 06:46:38
Engine speed: 855.50 /min
Normed load value: 27.1 %
Voltage terminal 30: 11.343 V
Preheat time: 0.0 s
Glow status: Post-heat
Extern.temp.sens.1 bank 1: raw value: 17.0 °C
15918 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [039] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35311 km
Date: 2031.01.25
Time: 06:46:38
Preheat time: 0.0 s
15920 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [039] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35311 km
Date: 2031.01.25
Time: 06:46:38
Preheat time: 0.0 s
15922 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [039] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35311 km
Date: 2031.01.25
Time: 06:46:38
Air mass at air mass meter 1: 39.6 kg/h
Standardised airflow ratio: 1.266 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 28.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Charge air pressure specified value: 1.123 bar
Absolute intake pressure: 103 kPa abs
Mean injection quantity: 6 mg/stroke
Index of current engine mode: 0
Index of next requested engine mode: 0
Index of engine target mode: 0
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 42126000000287
Coding: 307E4098256484870C7D027DA48A21F3790000
Shop #: WSC 02739 790 50316
VCID: 3FDB409467F7B1F36A1-806A
1 Fault Found:
0397 - TPMS Warning
C102D F0 [137] - Pressure Loss
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 47
Mileage: 35311 km
Date: 2020.08.23
Time: 06:46:34
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 02071613470298
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FD90207D78FB217-802A
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 73B3DCA41B3F25935E9-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 200160355
Coding: E0A4303A0A212031002009742C2B8C540F00708F60464D60320400220800
Shop #: WSC 02737 534 188775
VCID: 2A0D01C08CF5245B2DF-807E
Subsystem 1 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P
Component: J386__TSG_FT 003 0653
Serial number: KU0KU019071662016989
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 003 0653
Serial number: KU0KU020071662028142
Coding: 0400A0
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 47
Mileage: 35311 km
Time Indication: 0
Date: 2020.08.23
Time: 06:47:02
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V3001GEM4
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D31807CD594DB5DF-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 960 S HW: 7E0 920 960 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 450B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 392F2E8C79D39FC3545-806C
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8DC1C04CF5E45BEDF-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 055 7067
Serial number: 07061600011928
Coding: 065700003C00000041111101008000001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E050DD0B09D487BF17-807A
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001607160349
1 Fault Found:
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 47
Mileage: 35311 km
Time Indication: 0
Date: 2020.08.23
Time: 06:47:31
End----(Elapsed Time: 01:06, VBatt start/end: 11.5V/11.4V. VIgn 11.3V)-----
ENGINE Fault codes – 02
Sunday,23,August,2020,21:19:53:41168
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35311 km
Date: 2031.01.25
Time: 06:48:52
Engine speed: 1038.25 /min
Normed load value: 29.8 %
Coolant temperature: 31 °C
Intake air temperature: 17 °C
Voltage terminal 30: 11.289 V
Readiness: N/Ad
so you have codes stored for:
5 Faults Found:
03-ABS Brakes -- Status: Malfunction 0010 (prob will clear with a reset)
1 Fault Found:
0397 - TPMS Warning
BCM 1x fault logged. (prob due to flat battery)
1 Fault Found:
1 Fault Found:
02252 - Generator
so with all that you are looking issues with the glow plug system.
issues with no com to alternator
issues with BCM/ECM comms
This could be an absolute can of worms due to the unknown of whats happened to the van in the passed?
it could be an fault alternator? or damaged wires?
possible BCM/ECU/clocks swap to steal van? - are the key all original and working?
sound like a nice project to get into, but some advanced VAG diagnostics are needed.
you need to know about CAN & LIN bus diagnostics and some. decent back probes and testers.
if it was me, i would.
back probe alternator outputs and data connection back to ecm.
check main positive supply from alternator to ebox and starter battery.
read data PIDS for battery reg unit and alternator.
start with the main battery and charging problems first.
them move onto the engine glow plugs.
come join as a VIP member . . .
then you have access to all these downloads, including schematics and fuse layouts etc..
5 Faults Found:
1 Fault Found:
0397 - TPMS Warning
1 Fault Found:
1 Fault Found:
02252 - Generator
Thanks for advice, its much appreciated.
Yes, I have one original key that works. The van had been parked up with a dead battery for quite a few months. However it's very low mileage and generally in excellent condition.
It's going to be a process of elimination I think, I will try and work through your suggestions tomorrow, but will also remove the clocks to find out what has been messed with back there.
5 Faults Found:
1 Fault Found:
0397 - TPMS Warning
1 Fault Found:
1 Fault Found:
02252 - Generator
Hi,
I've pulled the clocks out this morning, found nothing too unusual, so have replaced them all correctly.
I then pulled the battery tray out and accessed the Big fuses and relays underneath and found Fuse Number 1 which is a 225Amp Mega fuse had blown.
I've ordered a new one from TPS. But I wonder what could have caused this fuse to blow? Most likely it is the cause of my charging problem though.
Any suggestions much appreciated!
As @Dellmassive says it would be worth you signing up as a VIP member. The fuse layouts in the download section will show you why you need to sort out your problems with fuse 1 and also the missing cable from fuse 8.
Yes, I do intend to sign up as it seems very worthwhile.
I don't think that fuse no:8 is supposed to have a cable there, I believe it is for different model vans after searching through the internet about it?
(There's certainly no cables loose underneath)
Fuse 8 is for the heated windscreen relay and the glow plug activation control unit. Maybe the unit including cable has been removed during the theft?
Oh Really! I saw on another forum it was possibly 'spare'.
I am also getting error messages on glow plugs so if that is the case with fuse 8, that might explain things.
Odd thing to steal though, since it would appear that nothing else has been touched/damaged on the van, and the battery tray and all parts to get at it were assembled correctly too.
Where is the glow plug activation unit located?
Also, How to I go about signing up for VIP?
