I did a bit of research on this last year and spoke to a very helpful guy at Offgrid Campers… thought I had it sorted.. but then looked into solar generators and went that direction instead. Bit more expensive but so much more versatile. I have a small Nespresso and an Ecoflow Delta now.Hi
Can anyone recommend a 2000w inverter or similar to run a coffee machine.
A decent one but not too crazy money.
Use this to power my sage barrister.Hi
And a microwave , induction hob and toaster700 quid so you can run a coffee machine
Didn’t I just see a picture of you having a full fry up at a pubAnd a microwave , induction hob and toaster
TBF - the electrics were one of my main focuses of the conversion.
Yup, we have a £10 Italian moka pot that sits on the gas hob. Makes superb coffee.I’m puzzled as to why after 600 years of coffee drinking mankind now needs a machine to make it.
So just do it up tight enough!I had a moka pot once, it did make lovely coffee but it also had a tendency to fire scalding hot coffee across the room if you didn’t quite do it up tight enough.
Well said. Wish more people thought that way.Shocking for waste too.
Nespresso claim their pods are fully recycled. It’s just up to the user to return them. We always do, naturally!I’m completely mystified by nespresso machines, we had one at work and all of the different capsules I tried were pretty nasty. Shocking for waste too.
Blown fuse for the socket?Hi,
I have a 12v system in my T6, with a cigarette plug which is powered by the leisure battery, I plugged a small inverter (300w) into it and it will not work even though the power is just over 12v, inverter works in the main van cigarette plug to the engine. Not sure why it doesn’t work?
Any ideas
