20” ET45
Innzey
Hi I’m looking for a bit of advice.
Want to get some new wheels for my T6.1 Highline, was looking at a set of 20” alloys with an offset of 45, will these fit ok….?
New to this….TIA
New to this….TIA
Are the alloys load rated for a T6.1?
Depending on the weight rating of your T6.1, the alloys need to be a minimum :
T28 = 800KG
T30 = 805KG
T32 = 860KG
Also tyres you fit need to be rated as a minimum:
T28 = 100
T30 = 101
T32 = 103
More info here:
The offset will depend on the wheel width. My fronts are 8.5j with an offset of 45 and fit fine. I think that’s pretty standard for that wheel width on the T6.
T28 = 800KG
T30 = 805KG
T32 = 860KG
T28 = 100
T30 = 101
T32 = 103
More info here:
Cheers mate
I’ll check that site.
The wheels I was looking at say they’re for.
New to this….TIA
T28 = 800KG
T30 = 805KG
T32 = 860KG
T28 = 100
T30 = 101
T32 = 103
More info here:
T28 = 800KG
T30 = 805KG
T32 = 860KG
T28 = 100
T30 = 101
T32 = 103
More info here:
Cheers mate I’ll take a look.
New to this….TIA
I'm running 20x9J ET45 - they're fine. Now I'm on 245s, I could do with a spacer on the back - maybe only 8mm
I’m running 20x10 ET45 and 275/35R20. Bilstein B14 Komforts. No issues on the flat but on full lock flexing up a kerb / driveway sometimes the tyre ‘just’ touches the wheel arch liner. Profile pic is current T6.1. Attached pic is previous T6 with same wheels.
What are those wheels?
