2 Devices Off 1 Fuse...
Ann3x
Run out of space in my DS fuse box in my camper conversion. The fuse box is properly supplied with thick cable.
Is there any reason I shouldn't run 2 outputs from 1 fuse? It's the last one I need and I'm loathe to change the fuse box as it's already a tight fit.
It'll probably just be 2x dual slot USB power sockets running off the 1 fuse.
I'm figuring as long as I over spec the wiring (1m run for each) I should be OK....
Views?
