150ps losing coolant
Broadside
I’ve been having problems with my van losing coolant for the last year and I’ve popped up on numerous threads when other people have reported issues, so time to start my own thread.
My van has got 120k miles on the clock, I had the EGR swapped earlier this year and the leak got better but didn’t stop. My local independent garage put some dye in the coolant and I’ve run it for 2000 miles until it used most of the coolant which was about 1.5 litres. The leak is slow and there are no visible traces of the dye anyway so it is probably getting consumed internally. After standing overnight it is not uncommon for the van to have a bit of a lumpy start for a second but it’s never bad and it runs very well apart from this slow leak.
The garage say the next step is to strip it down and get the head pressure tested. They’ve done this job on an A3 recently and it came out to £5k total. That is a game changing amount of money to spend on a van with 120k on the clock so I’m now in two minds whether to suck the bill up or get rid.
What would you do?
surely the first thing is to pressure test the coolant system to see where the leak is.
and maybe a smoke test as well?
water to oil cooler - is oil level rising / emulsified oil?
water to block - head gasket? - plugs or injectors might need to come out? (and possible cylinder compression test?)
water cooled charge cooler leak to charge inlet?
small rad leak - to atmosphere?
It has been pressure tested overnight a couple of times in the past year.
The oil level has started dropping in the last 5k miles, it never used to use any noticeable amount, maybe that’s the engine ageing or an indicator there is cylinder damage, but it’s expensive to find out. There is the usual bit of mayo at the top of the filler but no worse than it ever was. The dipstick doesn’t show any sign of gloopy oil.
They’ve stuck a scope in the EGR and also the charge cooler, no evidence of a leak in either.
You’re right it could be a head gasket but that’s a lot of labour to dismantle and reassemble so that bill would probably reach £3k without blinking.
I was hopeful of an external leak in a rad or pipework but the UV dye can’t be spotted anywhere external.
There is still a lot is could be but once it gets stripped down I’m locked in for the expensive ride, so I’m trying to work out if it’s worth it. It’s pretty depressing.
Also AdBlue injector has been checked for coolant leak?
How about auxiliary coolant heater and it's pump?
They are good questions @mmi
I need to check if the under tray has been removed to look at the auxiliary coolant heater, I don’t know if it has.
Can you expand on the AdBlue injector? I didn’t realise there was a coolant flow down to that.
I’ve spoken to the garage, apparently they did have the under tray off yesterday to check the aux heater. I’ve asked them to look at the AdBlue injector so they will do that today. Their advice was that the occasional lumpy cold starts are indicative of an internal leak and with the amount my van is losing there would be visible signs if it was external.
The replacement head with TPS is £1900 which starts to explain why the repair bill would be so high at £4k-£5k. So based on what comes back today this is probably the end of my T6 ownership as I cannot keep up with such big repair bills :(
Yesterday I was minded to not fix the van but then after spending the day looking at alternative vehicles I’ve realised that a £5k fix is horrible but cheaper than getting a replacement vehicle, so I’ve told the garage to go ahead with the fix. Gut wrenching but it seems like the right thing to do.
I need the van for a trip to the Netherlands at the end of July, fingers crossed it will be done by then but getting the head off and then pressure testing it will all take time. The killer could be a TPS parts delay if a new head is required.
I got my van back Fri afternoon, 6 hours before I was due to travel to the Netherlands.
It’s had the head replaced and on first starting it was only running on 3 cylinders, turns out an injector got damaged during the work so that has been replaced too.
I’ve driven it 400 miles since getting it back on Friday and all seems fine. I still have no idea if this fixes the coolant loss issue but after £5k I sincerely hope so…!
Hi All - apologies if this is the wrong thread but unfortunately there are plenty of similar threads:(. My T6.1 (2021 DSG 90k km) has been losing coolant slowly over the past couple of months - it needs topping up every couple of weeks. I have asked my mechanic to quickly assess and he has checked water pump and says zero sign of any leak. We are now moving on to EGR ! Can you please advise what is the next step - are there certain tests he can do on the EGR to see if that's the problem child before he whips the whole thing out and costs me a small fortune? Many Thanks for all your help
What would you do?
Hello, my car has been losing coolant for the past year. Initially, there were marks on the radiator itself, and after replacing it, the coolant continued to leak. Now we can't find any leaks; it passed the pressure test and there were no problems. A CO2 test was done, but there was a 10% color change, and the mechanic couldn't fully diagnose the issue. However, something you wrote caught my attention: I started my car this morning, and on the first start, it ran with such a knocking sound that I thought there was an earthquake. I stopped the engine thinking something was wrong, then restarted it, and it ran with this knocking sound for about 10-15 seconds before settling down. This only happened once in the last year since the coolant started leaking. I thought this knocking might be due to water mixing with the fuel because I never considered these problems before. I've been getting my fuel from the same place for 10 years, but this is the first time this has happened to me. Have you experienced the same thing? Could it be that the coolant reached the pistons overnight and accumulated there?
  • Sad
After I posted in July 2024 I never had any further coolant loss issues, in my case it was a cracked cylinder head which allowed small amounts of coolant in to the cylinders which was noticeable on the first start of the day but by no means everyday. Though it’s not impossible for fuel to be contaminated at the pump in my experience it is far more likely that a fault with the van will lead to water/coolant in the cylinders. Having to top coolant up was a minor irritation but what really concerned me was the possibility of a hydrolock causing big damage. Mind you my £5k repair bill was pretty eye watering!! Good luck with it, but if you are getting major lumpy starts then I would be getting it sorted out quickly.
