Hi all, just trundling down France and my 12v ‘gearstick’ socket has stopped working. I have a standard 12v cigarette male socket plugged in leading to a portable battery (input to this via solid Andersen plug). The battery is connected to a compressor fridge (2-pin connector to kettle-type fridge input). When driving I plug in the 12v to charge the battery. It’s worked ok for ages. Yesterday the battery stopped charging. The 12v socket felt quite hot, but it often does. I assumed fuse in 12v blown do replaced but no good. Played with the 12v plug and it looked ok. Tried a replacement (unscrewed the end from the 2-pin part and tried another ‘end’) but still no good. Got passenger seat off to find car fuse (as per another thread - thanks for that). Single 20A fuse in situ - blown. Replaced fuse and as soon as it went it, click, blown. So… can I assume the 12v socket in by the gearstick is faulty and causing a short circuit? Don’t think there’s much I can do about it if that’s the case. For info the twin USB C sockets both work so assume other fuse for them somewhere? I could try the other 12v socket on the dash but think this might also use same 20A fuse?
Any ideas most welcome, thanks.
