Hi all
I am sure these have been covered already but much of it is over my head wondering if someone had a quick simple answer for me, as I am no sparky. I have a T6 which I am part way through converting. I bought a leisure battery and a Victron DC-DC and had an auto spark install it but was not cheap. So I now have power from the starter to the leisure battery under the seat so job started.
Two quick questions.
1. I have a Victron 240v to 12v 30 amp charger to wire up now, the run is about 1 meter. Wondering what diameter/AWG cable I would need and if this needs a fuse on the positive wire?
2. I have a Sanjo SVR50L fridge to connect up too which has two wires coming out the back presumably to connect to 12v. From what I can tell this connects into my mini fuse board which will draw off the leisure battery. My question is can this also run off 240v or does it draw off the leisure battery which when hooked up to 240v is then topped up by the victron 240v -12v. In the instruction book it seem to mention a rectifier which from what I can see switches between 12v and 240v?
Any help on either of these would be great thanks
Dave
Dave
