speedo adjustment
  1. PondM8
    Dealer's responsibility - Recoding for 20s
    I've recently got my t6.1 camper from new. 20" wheels fitted and so I checked it was reading correctly, appears to be under reading by up to 3mph (common thread on here). My question, should this have been done by the dealer/converter, at the very least I should have been told. I can drive...
  2. S
    T6.1 Speedo Adjustment for larger wheels
    I am about to buy a set of Fuel Zephyrs for my T6.1 Shuttle running on 235/65/17 and as far as I am aware no one is yet able to tweak the calibration on the 6.1 software to correct the speedo, so was wondering if anyone has had any experience with this...
  3. S
    Speedometer Calibration on T6.1 for larger tyres
  4. OllieGBR
    Can you code for larger wheel circumference?
    I see that VW are also offering 20" tyres after a recent visit. Can you code the vehicle for a larger wheel/tyre circumference? Cheers Ollie
  5. S
    19” Tyre Recommendations
    Will these be ok on a T30 - 275/40/19 - 9 offset?
  6. K
    can you adjust the speedo for the tyre size?
    Oh my god, I'm going round in circles with wheels and tyres sizes! So if it's a 20" wheel the tyre will be a 265/40/20 for my t32 ( when I'll actually get it god knows! ) .. This will through the speedo out by 4%... Is there a way to get the speedo adjusted so that it reads the correct...
  7. Inthezone
    Hi Perhaps an old topic, I have just changed my wheels from 16" to 20", and thas you all know the speedo is out by about 7% according to will they fit .com My question therefore is there anyone in the Reading Berkshire area that can change the calibration for me?
  8. mmi
    [Guide] [T6_modified] T6 Speedo Adjustment with VCDS
    Module 17 – Instruments carries also the coding to select a few scaling factors for speedometer. Byte 0, bits 0..3 have mysterious value “K-number”. It turned out changing this coding adjusts measuring values IDE00842 (K-number) and IDE00845 (Wheel circ. mm) of module 17 - Instruments, and...
  9. Glenn Board
    Speedo Adjustment For Bigger Tyres
    Hi, I was going to have the Seikel raised suspension kit fitted to my van which includes 235/65R17 108H tyres being fitted to my standard wheels, they tell me that if they do s speedo adjustment to match these tyres that there is a possibility that the cruise control will stop functioning...
