I don’t think I’ll draw 170A, that’s just the capacity of a 25mm2 cable.170A over 25mm2 and 30mm2 on a 4.5m run still shows a volt drop.
Using this calculator, it shows using a 70mm2 is recommended for that run. (12.2v 170A 4.5m)
Voltage Drop Calculator | 12 Volt Planet Cable Calculator
Use our Voltage Drop Calculator to select the correct Cable for your campervan, motorhome or boat wiring application. Cable Calculator for Auto and Marine Electrical Components from 12 Volt Planet - Cable Size Calculatorwww.12voltplanet.co.uk
View attachment 296376View attachment 296377
So my load current draws calculate as follows:
- Inverter 67A (that’s 800W/12V)
- 12V circuits add to around 21A
- B2B DC-DC upto 60A
Total 148A
But is my load calculation correct? Should I be including the DC-DC load as this is from SB to LB and nothing to do with the inverter?? If so then that reduces to 81A and so from the calculator a 35mm2 cable is in limits - also considering that the calculator accounts for a return cable length (so effectively doubling the 4.5m) opposed to using the van body as the return.
