£20 on a roll of foil insulation from Screwfix. Made a full set of thermal window blinds & a liner for the poptop. We use it all year round, keeps it cool in summer, warm in winter & quiet & dark all year.
Door seals are my wish id never bothered mod, sick of the door taking two attempts to close and walking away from the van and not hearing the beep of my alarm sounding and having to walk back to shut the door properly.
My doors are still shutting perfectly - have not even come close to bouncing off the seals. It looks as though there are many different options, and a small change in dimension, material and fitting location could make a big difference.
Good tip, think I'll try this. I had to turn off the tear wipe function as that final juddery squeak of a pass meant that it left the windscreen in a worse state than before.Replaced the stock windscreen wipers with Bosch all round. Not it's totally silent rather than a juddering noise fest !
Any photos @Salty Spuds how you attached them to windows and pop top ? cheers£20 on a roll of foil insulation from Screwfix. Made a full set of thermal window blinds & a liner for the poptop. We use it all year round, keeps it cool in summer, warm in winter & quiet & dark all year.
T6 - 66 plate
Replaced the stock windscreen wipers with Bosch all round. Now it's totally silent rather than a juddering noise fest !
Edit: just remembered I tried the Goodyear Stealth ones from Costco, rubbish. If any have the same problem go straight to Bosch !
Me too, got a drawerful of the things! Looking forward to the budget allowing me to get a Carplay stereo and ditch the holder altogether, got one in the car and the phone gets plugged into a USB in the storage box under the armrest out of the way, much better.A brodit phone holder.
Dread to think how many useless holders I’ve bought over the years.
Will the AP24U fit both the driver side and passenger side blades, ie are they both the same size? If so I'll order two tonight, my blades are juddery and leave smeary gaps at the top.
Re. The window blinds. We made them a tight fit within the window & “thumb” them into the sealing rubbers. The curtains do the rest.Any photos @Salty Spuds how you attached them to windows and pop top ? cheers![]()
If you order the LHD model too, you can have “his & hers”
Buy a Brodit Apple iPhone 7 Car Holder | UKWhere did you get the Brodie from?
View attachment 33740 View attachment 33741
The inner roof liner was a tad more technical. We templated the roof canvas (it’s deceptively “un square”). We cut insulation to match the roof canvas panels & made corner hinges with gaffer tape. We taped plastic rods into the front vertical corners to give support. The liner is a tight fit top & bottom between the roof lid & base frame. Some spring loaded net curtain poles from Wilko hold everything in place. Sounds more complicated than it is.
