Which chainsaw?
Steve Hales
Getting a log burner installed soon and I’ve been on the lookout for a chainsaw I can chuck in the van so whilst I’m out if I’m offered any wood I can chop before loading onto the van.
I’ve looked at petrol but with the battery technology being pretty good now days I’m probably going down that route, has anybody got any advice on any to look out for and any to avoid?
Personally I would go for Stihl either petrol or battery both have their pluses and minuses battery once its flat your done petrol bad petrol or wrong mix lack of maintenance = knackered engine and more importantly is safety get yourself a pair of chainsaw trousers and a helmet with visor at least and learn how to sharpen a chain nothing worse than a blunt chain
+1 for battery Stihl range. I have the mower, hedge cutter, brush cutter and blower and they are all brilliant.
The arborists at work also all use Stihl and many have moved over to the battery climbing and ground saws to reduce risk of HAVS. Just a few extra safety things to worry about like remembering to remove the battery when not in use/ maintaining.
+1 for Stihl, I had a Jonsered before, got a Stihl MS 171, world of difference! Can‘t comment on battery version but Stihl’s build quality, parts and backup from dealers is great.
I have a Stihl petrol one, gifted relatively unused by the father in law. I’m in Broughton Astley - you’re welcome to borrow it / have a go as it mainly sits in the shed.
It usually needs the chain removing and soaking despite spraying with WD40 after use (as mentioned it could be 6months between uses). As others said, learn to sharpen the chain (mine came with a new Stihl file).
Once fired up, it cuts through large branches / trunks with ease (up to approx 30cm dia)
Somewhat controversial, but....
I don't know what chainsaw experience you have, but I think that an experienced user wouldn't have asked the question.
Please consider doing a chainsaw operators course and buying chainsaw boots, over trousers, gloves, helmet etc. before using or buying a chainsaw.
None of that is cheap, but a chainsaw is the most unforgiving tool in the world, chainsaw injuries tend to be horrific. Even when cutting up a fallen tree there are tensions in the wood that have to be dealt with in a certain way if you want to stay safe.
With the current fuel cost crisis I'm sure a lot of people are thinking of buying a chainsaw, sadly some will pay a high price because they aren't the right sort of people to be using one. Sharpening a chainsaw chain is a skill, it's more difficult than most people think and a incorrectly sharpened saw will create a world of problems.
I have a policy of never cutting alone - if something goes wrong when you're using a chainsaw it won't be a job for your home first aid kit and you won't live long enough to wait the 6 hours it'll take for the ambulance to arrive, if you can use your phone. Have somebody nearby to help in an emergency.
Anyway, if I haven't talked you out of it....
Battery chainsaws are excellent nowadays but with batteries and a charger it's a big investment for an occasional user, I'd go petrol in your circumstances. I'd also use a pre mixed fuel like Stihl Motomix, which will not go off in your carb and tank if left unused for a couple of months.
I don't use my chainsaws during the summer so at the end of winter I make sure my last tank is Motomix, it doesn't gum up the carb over summer like a normal 2 stroke mix does.
There are several good chainsaw manufacturers out there but you really can't go wrong with Stihl and spare parts are readily available.
You almost certainly don't need bigger than a 14 inch bar.
You'll also need to know about seasoning firewood, different species, and splitting wood.
Most importantly, stay safe.
top advise from DaveD
indeed - I'm pondering selling mine now. Not had training nor have any of the equipment mentioned. I'm always very careful, gloves and safety glasses and plan out what I'm doing (only suburban small tree pruning/removal) which could probably be done with a bow saw or big axe [I have one of those too, well several :oops: ]!
Whilst Stihl is the best make and training is advised, for what you describe a cheaper battery saw would do you.
I used a Ryobi battery chainsaw yesterday and was quite impressed. The sharpness of the blade is more critical than the brand for light use.
I use a Husqvarna 135 on my allotment, it’s petrol of course, a great bit of kit, I treat it abit mean but it never lets me down, most important thing is safety equipment and keeping the chain sharp
Top advice from @DaveD indeed! I used to do some work with a qualified tree surgeon and I was always very impressed with how methodical he was…. working with trees/fallen trees/broken limbs of trees should not be underestimated in anyway…. the shear weight and forces involved can be incredible. You have to think about it, think again, then make your cut carefully (think twice, cut once) and you need eyes in your backside! Plus all the safety equipment (PPE) as mentioned above.
Just a thought, but what about a battery recip saw…. Makita or Dewalt for example?
another thing to consider is if your going to use it at home is noise a petrol saw will p**s the neighbours off on a sunday morning
for at home I started using an electric chainsaw still as dangerous still needs PPE
For cutting anything less than 8 inches diameter (although capable of cutting through bigger stuff) these are very quiet, free to run and relatively safe, they are incredibly sharp and go through green wood like nobody's business!
No batteries, no petrol and easy to carry. Always got mine in my van, I'd never leave a chainsaw in the van.
recip saws are ok for very short periods of time but they burn through batteries quickly and the HAV is chronic 10 minutes of use and you know you've been using one
I have had the pleasure of using a Milwaukee battery chainsaw for work last week I don’t think I will ever use my petrol stihl again, just as powerful and no irritating noise of an engine between cuts like others have said ppe and training are a must with chainsaws
If you're 'in-bed' with a particular brand for other battery hand tools then buying a bare unit can be a very cost effective way of getting a chainsaw. Exactly what I did with my Makita saw.
Just reuse batteries & charger that I already have.
It's astoundingly good bearing in mind what it's powered by (2 x 18v batteries) and what it cost me! Obviously it doesn't have the ooomph of a petrol saw, but if it's just lop up the odd log and you're not a tree surgeon using it all day every day then I'd give a thumb up for battery chainsaws!
There is no way an electric chainsaw can match a petrol one when you are chopping several tons at a time
One thing that is very useful the screwfix 4 ton titan log splitter for £200 saves a lot of axe work
