Wheels And Tyres Staggered-will They Fit A T30?
Dm85
Can anyone out there confirm if or if not these alloys will fit a t6 t30?
  • .front) R20x9, 5x120, ET35, 72.6mm
  • (rear) R20x10, 5x120, ET38, 72.6mm
It’s fine margins and can be an expensive mistake
Hi rears ok but fronts will stick out a bit I have 20x8.5 et35 and they are flush with the wings
Thanks, I don’t want that.
What suspension/lowering do you have? I was looking at b14’s but was looking at 50mm lowering springs. Bit worried it’ll be a bumpy old ride. I have 30mm lowering with 18’s atm
If it helps this same spec, ET’s but an 8.5 in the front and 10 rear. On B14s with machined top mounts at the front so about 80mm down with back a bit less. Very close to the arch at the front but with a bit of manipulation of the arch liner it doesn’t touch at all now.
I do really like the staggered look!
