Wheel sensors.
Periscope007
Hi, Carista tells me right rear sensor is faulty, is this part accessible by removing the wheel? If so, would I need any other support, safety wise, besides the supplied jack?
Sensors are usually well stuck and tend to snap taking them out. Is yours 4motion or not? If not it's a little bit easier, apparently you can access the sensor tip by popping a plastic cover from within wheel hub. On 4motion you need to take the sensor out from outside of the hub - I ended up using dremel for ages to get the tip out.
And as @Deaky said, don't trust the jack. Support the vehicle properly, you will most likely need to spend some time with your head in the wheel arch.
