What voltage should my starter battery sit at ?
JumpShip
T6 Legend
With the ignition off my battery is sitting only just above 12v and drops to 10 something when starting.
With the engine running its 14.2 /14.3v which is what I'd expect.
Current batt is about 6.5 years old .
Van gets a good run on a weekly basis , not sat around .
What do you reckon ?
How much use do you get out of it before it needs charging though? Can you get a night or two away out of it?
12.2v - 12.6v resting.
Down to 9.0v starting.
13.6v - 15.0v engine running.
It's my starter battery not leisure ;).
It's not let me down yet but just seems to have lost a little 'sparkle' when turning over .
We're away for 90 days in spain in a couple of weeks time so I'm trying to crack off all those little jobs .
I would get a new battery in there! You've only got to be stopped for a 2/3 nighter for the battery to let you down for the first time with the doors opening and closing several times draining the starters powers. Or make sure you're carrying a noco boost. Unless you're on EHU of course, with something to charge that starter.
50w dash solar plugged in to the 12v socket.
