I’m preparing my van for the installation of the alternator side of the split charge system. Everything has been disconnected or dismantled so I can remove the fridge/battery/inverter/larder cabinet fo access the installers wiring. However, I also have the shower pipes running up the side to the outlet, which needs disconnecting. They are push fit connections, but my knowledge has now run out. Can they somehow be unplugged or is their use a one way journey? If so, I’ll leave them as they are, cut the pipes for cabinet removal and on re assembly, connect further down the pipe with a couple of straight connectors.
