Found VW wheel locking bolt key D
pixelmix
Does anyone have a spare VW locking wheel nut key with code "D"?
This is the 19mm version for T6 obviously, not the 17mm for VW cars.
My existing key is slightly damaged so I want a fresh / good condition key to safely remove my wheels.
If nobody can help and you are able to remove the existing wheel bolts with your current key, it might be easier to source a new/second-hand set of locking bolts and key?
I've found one on eBay now so I'll delete this WTD if it turns up and is okay.
I could keep trying with my current key (I think it is the key rather than the bolts which is damaged) but I'd rather have a clean key rather than damage the bolts and be in a bigger issue. Unless there is a marked difference in the new key and existing bolt combo (i.e. there isn't lots of play in it), my plan is to remove the current locking bolts.
