For Sale Victron Energy SMART BatteryProtect 12/24-Volt 65 amp
Dellmassive
VCDS User
Moderator
T6 Master
Victron Energy SMART BatteryProtect 12/24-Volt 65 amp​
little use, was installed when i was running AGMS,
BT version.
RRP £45
£20 collected + shipping
One of the best ways to shorten the life of a lead-acid battery is to repeatedly over-discharge it. This can lead to damaging sulphation that impairs a battery's ability to accept and maintain charge. The Victron Smart Battery Protect 65A solves this problem by automatically disconnecting your battery from non-essential loads before it reaches a damagingly low state of discharge. When the battery voltage drops to a certain level (lower threshold) the loads will be disconnected and when it rises again to a certain level (upper threshold) they will be reconnected. These thresholds are user-configurable to suit your application.
The Smart Battery Protect has a host of other features (see below) and is easily configurable using the built-in Bluetooth in conjunction with the VictronConnect app (see Downloads/Links tab). The voltage thresholds can aso be programmed manually using a dedicated pin on the terminal block and the Bluetooth function can be disabled if preferred.
It should be noted that the Smart Battery Protect is not designed to accommodate reverse currents from charging sources, so these should not be connected through the device. It may also be desirable to have essential loads (e.g. VHF, lighting) routed outside of the device so that these can always be used, regardless of the battery voltage.
Box contents
  • Smart Battery Protect
  • Connector with pre-assembled DC -ve cable (10mm ring terminal)
  • Instruction manual
Features
  • Prevents batteries from damaging over-discharge
  • Can act as a master on/off switch for your loads
  • 12/24V auto-ranging
  • Built-in Bluetooth connectivity for easy programming and configuration
  • Special setting for Lithium batteries (device can be controlled by the VE.Bus BMS)
  • Ultra-low current consumption
  • Over-voltage protection to prevent damage to sensitive loads
  • Ignition proof (uses MOSFET switches not relays)
  • Delayed alarm output (prevents nuisance alarms during transient high voltage-drop e.g. during engine start)
  • Alarm output (50mA max.) can be used to activate buzzer, LED or relay
  • Delayed load disconnect and reconnect (to avoid reaction to transient high/low voltages)
  • Easy-connect terminal block
  • LED indicator to show selected voltage threshold programme
Specifications
Manuals & Guides
Customer Reviews (0)
Victron Energy is at the cutting edge of power management technology, offering a range of innovative and highly reliable products for every leisure application. This highly respected brand has a wealth of experience in the automotive, industrial, off-grid, marine, energy-storage and telecoms sectors.
more stuff here --->
