Brand New in Box Surplus Stock. Victron Phoenix Pure Sine Wave Inverter - 12V 500VA. Can be shipped at buyers cost, or collect for free from the cave, South Petherton, Somerset, TA13
- Input voltage rating: 9.2 - 17.0VDC
- Output voltage: 230VAC +/- 3%
- Continuous AC power at 25°C: 500VA
- Continuous power at 25°C/40°C: 400/350W
- Peak power: 900W
- Max. efficiency: 90%
- No-load power consumption: 6W
- Default zero load power in ECO mode: 1W
- Operating temperature: -40°C to +65°C (fan assisted cooling)
- DC low shut down: 9.3V (adjustable)
- Dynamic (load dependent) DC low shut down: Fully configurable
- DC low restart and alarm: 10.9VDC (adjustable)
- Battery charged detect: 14.0V (adjustable)
- Cable connection: Screw clamp terminals (cable size 10mm² max.)
- Output socket: BS1363 UK 3-pin socket
- Remote On/Off connection: 2 pole connector
- Ingress Protection rating: IP21
- Body material: Steel with plastic cover (blue RAL5012)
- Mounting holes: x4 on sides of chassis
- Weight: 3.9kg
- Overall dimensions: 275 (L) x 172 (W) x 86 (H) mm
