Monday,19,January,2026,23:12:59:32837
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZKH179200 License Plate: ##69###
Mileage: 206480km-128300mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZKH179200 Mileage: 206480km-128300miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CXGB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 RP HW: 04L 907 445
Component: R4 2.0l TDI H02 6748
Revision: 23002001
Coding: 00114014432401090000
Shop #: WSC 00012 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056RP 004002
ROD: EV_ECM20TDI03004L906056LT.rod
VCID: 0C467AB206C3533AE2B-8058
VINID: 9E606AAAA1D8A9B6011C908000CE9CA3A5
21 Faults Found:
32111 - Voltage Supply for Particulate Sensor
P24D0 00 [00100000] - Short to GND
Intermittent - Not Confirmed - Tested Since Memory Clear
25144 - Control Module 1 for Cooling Fan
P1945 00 [00100000] - Output Short Circuit
15908 - Glow Plug Control Module (J179)
P0684 00 [01100000] - Implausible Signal
15911 - Glow Plug Control Module (J179)
15917 - Glow Plug Cylinder 1
P066A 00 [01100000] - Short to Ground
15919 - Glow Plug Cylinder 2
P066C 00 [01100000] - Short to Ground
15921 - Glow Plug Cylinder 3
P066E 00 [01100000] - Short to Ground
15923 - Glow Plug Cylinder 4
P067A 00 [01100000] - Short to Ground
16056 - Oil Pressure Switch
P164B 00 [01100000] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Mileage: 205641 km
Date: 2025.12.21.
Time: 11:47:42
Engine speed: 1787.25 /min
Normed load value: 90.2 %
Vehicle speed: 37 km/h
Coolant temperature: 30 °C
Intake air temperature: 9 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.781 V
Unlearning counter according OBD: 29
Air mass at air mass meter 1: 198.0 kg/h
Standardized air flow ratio: 1.047 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 34.50 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 63.33 %
Charge air pressure: specified value: 2.258 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2066 mbar
Mean injection quantity: 48 mg/stroke
Index of current engine mode: 7
Index of next requested engine mode: 7
Index of engine target mode: 7
30250 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [00100000] - Implausible Signal
31391 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0105 00 [00100000] - Malfunction
34399 - Reductant Quality Module
U05A3 00 [00100000] - Implausible Signal
32165 - Control Module for Reductant Quality
U02A2 00 [00100000] - No Communications
27277 - System Voltage
P0562 00 [00100000] - Too Low
25602 - Starter Control Circuit
P0512 00 [01100000] - Electrical Malfunction
25126 - Implausible Data Received from ESP Control Module
U0416 00 [00100000] - -
27202 - Sensor Reference Voltage A
P0641 00 [00100000] - Open Circuit
27200 - Sensor Reference Voltage B
P0651 00 [00100000] - Open Circuit
27198 - Sensor Reference Voltage C
P0697 00 [00100000] - Open Circuit
27196 - Sensor Reference Voltage "D"
P06A3 00 [00100000] - Open Circuit
38427 - Sensor Reference Voltage 1
P06A6 00 [00100000] - Implausible Signal
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 62229000000919
Coding: 867E40982569848761770276A48221A679F100
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDC9D7E07F5B8A2B79-806A
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 09081913471657
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA2207A407F71AAFCF-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H23 0708
Revision: 00001003
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 73B4014E7B3D2CC2831-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8602 218190278
Coding: A0A4303A0A61343193284F746CEB8E740F84708F60CC6D60330400220840
Shop #: WSC 66305 000 1748809
VCID: 2C06DA32E603333A02B-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 020819 05 50 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0653
Serial number: KU0KU030071992110675
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 004 0653
Serial number: KU0KU025071992061981
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H02 0103
Serial number: 39190001238040129243
Coding: B0FFFF
1 Fault Found:
00077 - Windshield Wiper Stop Switch (F229)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 230
Mileage: 206173 km
Time Indication: 0
Date: 2020.05.31.
Time: 20:59:54
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32931912203486
Coding: 10800A
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 43D4918E6B1DDC42D31-8016
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 0308190439A5CF Dataset Number: V03935300XV 0001
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 3632F85A28CF79EA64F-8062
2 Faults Found:
1380 - Internal Fault
B200F F0 [00001000] - -
[FAULT_ADC_VZ_BELOW_RADAR_OPERATION_LIMIT]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 205894 km
Date: 2025.12.27.
Time: 11:21:40
Control Module temperature: 22 °C
Voltage terminal 15: 6.9 V
Vehicle speed: -0.21 m/s
Acceleration: 0.13 m/s²
1538 - Tire Diameter Implausible
C10A8 00 [00001000] - -
[FAULT_EVI_TIRE_SIZE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 243
Mileage: 201139 km
Date: 2025.07.04.
Time: 15:33:30
Control Module temperature: 37 °C
Voltage terminal 15: 13.1 V
Vehicle speed: 17.25 m/s
Acceleration: 0.29 m/s²
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 J HW: 7E0 959 655 J
Component: VW10Airbag021 010 0018
Revision: -------- Serial number: 003EK005RTGS Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3D20E7760DF9AAB2A55-8068
1 Fault Found:
9682162 - Multiple collision brake
B13BC F2 [00001000] - No function
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 195465 km
Date: 2024.11.10.
Time: 04:32:18
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 971 A HW: 7E0 920 971 A
Component: KOMBI H03 2050
Serial number: 00000000000000
Coding: 450B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 29082326E9712612F9D-807C
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 042305
VCID: 688E6622327BDF1A263-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 2050
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8A1C2A2CF7ED0A307-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 070 7205
Serial number: 14081900011331 Dataset Number: V03935266VJ 0001
Coding: 065700003C00000041111101008000001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E02D03AD09F412A2CF-807A
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 D
Component: Batt.regelung H82 0762
Coding: 030B7A73
Shop #: WSC 12345 123 12345
Subsystem 1 - Part No SW: 4K0 915 181 A HW: 4K0 915 181 A
Component: J367-BDMConti H03 1050
Serial number: 758852020019071501FB
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 122
Reset counter: 238
Mileage: 0 km
Time Indication: 0
Date: 2025.02.22.
Time: 15:21:44
End----(Elapsed Time: 01:56, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
------------------------------26 Faults Found------------------------------
