Vanslam Height
Lee
Hi all,
I've got VanSlam coil overs and apparently they are set as high as they will go, which is perfect for me. Does anybody know what the height distance is likely to be with this and a standard van height setup?
Lee
Hi all,
Lee
According to the blurb - "The VanSlam coilovers allow the ride height of your T5/T6 to be adjusted between -40mm - -70mm for an aggressive look and a sporty ride."
Hi lee can I ask what wheels your running tyre size I’ve also just added van slams and having a little issue. Thanks. Nathan
so I changed the wheel and tyre set up a few months ago, I have 18" wolfrace munich wheels, tyres are Khumo 255/45/18.
I did have 20's with 35 low profile tyres, there was very minor tyre rub at full lock, very minor.
when I changed wheels I also had the van raised to as high as the vanslams go.
hope that helps.
Thanks I’m trying to run 20” 275/40/20 and having issues. I was told today to drop to 275/35/20 and my issues will do and what you just said matches up. Thanks lee
