Thanks guys,
I was reasonably sure the passenger side would be OK, it was the drivers side I was more worried about. I probably won’t get to it for a week or two so I’ll report back once I’ve done it
Yep, all installed with no dramas. A couple of pictures in the post below:How was the result in the end? I also have twin sliding doors, I also would like to place a socket there and I’m not sure about driver/passenger side (and it’s more confusing being a left hand wheel drive...
Generally people will take a power feed from under the passenger seat, under the carpet and up into the B pillar area.Is there any how-to's on how to wire these in? an help appreciated.
As above (post #10) and you can use a relay to switch the power on and off with the ignition if you want it to be isolated with the engine off.Is there any how-to's on how to wire these in? an help appreciated.
