Hi!
Firstly I'll apologise if this has been answered before, I've hunted through the forum but I don't think I can find answers that enable me to figure it out. Now that might be just because I'm being a bit thick today!
My 2019 2.0 TDi, engine code CXGB, had been suffering flashing coil light and reduced engine power (now stopped) and then moved on to missing oil level/temperature sensor signal warning in the MFD. That's now coupled to U1091. I want to check the wiring to the sensor and if necessary change it but first off I need to locate the damn thing! Can anyone point me to a diagram that shows where it is located on the engine? I've found various diagrams but some refer to low pressure oil switch, some to oil sensor etc. but I'm not sure exactly which one is linked to the U1019 code.
Many Thanks for any help.
