Tyre Pressures for 255/35/20 - 97
Mark Banks
Tyre Pressures for 255/35/20 - 97, Anyone know what the correct tyre pressure is for this tyre?
And before anyone goes on a big one about load ratings, the T6 doesnt carry anything other than 350kg of people!! So dont panic.
Any help much appreciated.
If you are getting close to your load rating, I would edge towards a higher pressure; because most tyres carry more load with higher pressures.
What is the maximum cold inflation pressure for the tyre?
That could be your answer, if your are happy with the loadings, if in doubt you could pop along to a local weigh bridge and check your axels weights when fully loaded, and make a note in the van regarding the reduced capacity......... just a thought. A T6 is a big space you could easily overload one day accidentally, just offering a hint of caution.:thumbsup:
