Tsi engine number location
Dempsey
I'm trying to find the engine number location on my tsi so that I can register it and I'm struggling. Can anyone direct me better, I can see a flat spot on the right side of the block immediately above the gearbox join but I can't see any numbers there.
Scratch that I've found it. It's on the front right of the block and it's on a vertical not horizontal flat spot.
Hi I'm also having trouble finding mine. Could you point me in the correct area. Or describe exactly where to look. Cheers
I've circled it red. I had to use a borescope because it's blocked by a few things so you kind of have to look around a blind corner.1000005816.webp
I also had to clean it off with a long pipe cleaner brush, which I used whilst looking with the borescope, before I could see there was a number at all.
