Tips Fitting Cbe Electrical Goods!
CALLAKN
Electrician / Linesman
T6 Legend
Hello lads,
any tips for fitting these to the panels of my van?? What’s the best way to go about it??
thanks in advance !
After fitting several of these to previous Caravans and several Motorhomes, the best tip I can give you is common sense really. Think about what you will be plugging into the sockets and position them strategically. For instance, one Caravan manufacturer has one of these sockets above a gas hob, meaning anything plugged in whist cooking is a potential hazard. I've seen them fitted low down near beds for charging phones, but too far away for normal charger leads, meaning a phone on the floor. Just imagine what you're using each plug for, the length and route of the appliance lead you're plugging.
I can imagine you're fairly restricted where these can be installed in a T6, giving the depth of the actual socket unit, but careful mocking up works wonders, all stuff you know about.
I always use a specific size circular hole saw bit in the drill to cut the holes they need to fit in. They’re designed for a circular hole even though you’ll see muppets on YouTube cutting a square hole.
I worked out the best locations by going through converters’ website gallery pics.
Thanks lads.
I presumed when I first got them it was a hole saw job, just wanted to make sure so I didn’t cock anything up! Yes strategical planning @Tourershine ....
all of this in time for our Rutland water meet might be done by then
