I'd consider doing it yourself. It's really simple. Undo the bolts in the bottom of the double seat base. Remove the extra posts that will no longer be needed from the floor. Bolt the single seat base to the remaining posts, bolt your swivel plate to the top of the seat base and bolt the seat to the swivel plate.
You will be ok with leaving the air bag as is because you're going from a double to a single.
Have a look at the thread below for making good the two small holes left in the cab flooring.
I'd say it's a 30 minute job at best.
Hi – I've recently swapped out my factory bench seat for a single/captain seat on the passenger side... As there's only 4 bolts for the single, I have now have two fixing points protruding from the cab floor, so looking for some advice on what to do with them. It looks like they can be removed...
www.t6forum.com
