T6 Caravelle Strange Power Issue
DragonDubz
Hi
I am just posting to see if anyone has any ideas on what this issue could be. I have just purchased a 2017 Caravelle gen 6 which is very nice but has developed a strange issue. It has gone into a limp mode and will not go above 60mph. There are no fault codes showing when scanned with VCDS, can not see any pipes off or breaks and drives fine other than no power. Can anyone give me any idea what i could check to solve this as i am now stuck as it is not showing any faults on the dash or when scanned.🤔
Hi
I take it the OBD port you are plugging into is real and not a security fake/decoy version?
Please post VCDS engine blockmaps
1) Ignition on, engine off
2) Engine idling
I would check DPF differential pressure.
Its at the garage at the moment they are trying to find out whats wrong. Thank you for your advice i will let them know and see if that helps them solve the issue.
Yes its the correct one reads everything and can see live data etc. Its in the garage at the moment they are trying to work out what is wrong so i thought i would ask on here and see if anyone had any ideas so i can tell them and get it back soon.
