T6 uses the following BCMs: 7E0 937 090
7E0 937 090 B
7E0 937 090 C
7E0 937 090 D
7E0 937 090 E
Last 2 variants D & E can't have remote control paired via simple VCDS adaptation process.
C variant seems to be the best choice but B also provides the same retrofitting capability.
Basicly I’m runing an audi conversion in an old t5 but with the t5.1 cluster so I wondered as the t6 is smart charge ( Lin bus ) wonderd if a t6 module would Suport this ? And also t6 electric windows do they have to be run threw a bcm for them to fuction, also with t6 same having dsg. Possible been compatable for few gearbox u faults /
Not to meantion I’m running a t6 electric rack
Depends what functionality you are looking for. Comfort operation like, remote windows rollup, power mirror fold up require LIN-BUS communication between BCM and door modules.
Regards windows just so they open/ close via door switch ( as I don’t think they would work without bcm/ thankyou for advise nice to have a battery light as the t5.1 cluster is smart charge but can isn’t compatible with cluster ( Hernce as I’m now going t6 dash conversion wonderd if later cluster maybe compatible with cluster
I did see it but was sure if all bcm pin data was same ( personally only bought it to see if it will power heater controll pannel / cruise/ possible electric windows ) as my conversion is all audi
