T6 Awning solution multi and thule omnister/f45s
Jais
Hey is it possible to have an solution where we can fit both an awning like the Thule Omnister / Fiamma F45 or similiar and also have the option to easily deteach and then install an full blown tent like an Campa air tent ?
We really would love to have the option to fit both depending on the usage we need.
We have an T6 LHD LWB Transporter
Looks super but not exactly what i ment :) We would like to be able to add an actual tent to the car aswell as havning the normal f45 awning :)
I know. I'm trying to demonstrate the fact the F45s has channels on its front to attach your awning of choice without having to detach the F45s.
@Jais close up of F45s awning in 'closed' position. What others are trying to say is you can use the grooves on casing to attach awning, sun shade, tent etc. The gap between awning and fixed awning can be blocked using a length of pipe insulation etc. The F45s looks to have same size (perhaps 6mm) which can be slotted front to back or back to front....
